Hi I’m trying to link a file using Add to a project with a card.
after adding a file it is not showing to other user whom the card is assigned and board is shared.
Is it a known issue? Or something is wrong on my end.
Hi, we have the same problem. I can’t click the folders I want to browse and link and the dialog window seems to be frozen.
But it was a bit problematic even before when the connected files took very long to load and become visible on the card.
Any help would be greatly appreciated
Hello and welcome to the community support forum
I assume you are sufferung from this issue:
opened 08:24AM - 15 Nov 22 UTC
feature: projects
![image](https://user-images.githubusercontent.com/37149722/201865372-72effd64-c… 514-452d-9d8a-fb3897dd4c9f.png)
Links between cards and projects are gone, and I also can not set up new link
Docker FPM 25.0.1
PHP 8.1.12
Deck 1.8.1
Given this is a decision made by the Nextcloud GmbH, the community can’t solve this and I kindly like to ask you to join the discussion in the linked issue and in this issue in the Nextcloud core repository:
opened 10:24AM - 05 Aug 21 UTC
enhancement
design
1. to develop
client: 💻 desktop
client: 🤖🍏 mobile
feature: projects
It is proven by now that people don’t do the manual picking and connecting of pr… ojects. Nextcloud should be intelligent enough to show related folders, Deck cards, events, conversations, etc. automatically.
The idea is to show folders, Deck cards, calendar events, conversations, etc. which are shared with the same group or circle. This should give useful links to other resources in 90% of the cases without manual interaction.
### Proposal
* The manual "Projects" entry is expanded into a "Related resources" (wording not set, but nicely alliterated) section below the share list.
* Alternatively, and if we actually introduce a "Details" tab at some point, we could also think about moving this "Related resources" section over there. This might be needed cause the sharing list can grow quite long.
* There is an explanatory subline "Anything shared with the same group of people will show up here."
* Below is a list of the related resources. They have sublines with relevant info like last message for Talk conversation, column and board for Deck cards, or dates for Calendar events.
* If any of the entries is clicked:
* First step: Just like for Dashboard, you get redirected to that relevant item, opening it in a new tab.
* Ideal future (also just like ideally for Dashboard): A simple modal opens with further detail on that element only, making for much smoother UX than a redirect and full loading of an entire page.
![Share overview with new related resources](https://user-images.githubusercontent.com/925062/128334296-5c2c41b7-6b54-4e73-9589-671b01bcb4a8.png)
### Questions / beyond minimum viable product
* How would it show up in other apps:
* In Talk it would have to show up in the "Details" tab
* In Calendar in either "Details" or a new tab
* Can people dismiss entries which are not fitting? (Probably not in the first version)
* How can someone see all the resources of a "Project", if that even exists?
* Initially, any of the sidebar entries will do, as all of them should show the same.
* Additionally, we could show the entries in Contacts/Circles in the relevant section. (Not really possible for groups)
cc @nimisha-vijay @AndyScherzinger @skjnldsv as discussed. :)
Please read the whole threads before addding your input to not repeat opinions. Think about using GitHub reactions ( ).
