Iām trying to add a simple feature I am not a pro developer by any means. I want to be able to open a custom link/location containing the filename.
I understand that I need to add the option to the regular āfileā app which then be automatically accessed by the ārightclickā app.
I probably need to add something in one of these files:
./apps/files/js/filemultiselectmenu.js
./apps/files/js/fileactionsmenu.js
./apps/files/js/fileactions.js
./apps/settings/js/federationscopemenu.js
./apps/files/js/mainfileinfodetailview.js
but adding default menu options seems to have no effect
Can someone help point me in the right direction? thank you
if I got you right you want to perform a download to specific location and open using specific app?
If this is true you canāt achieve this task by changing Nextcloud. all the file handling like downloads destination and (possible local application loading) happens in the browser on your client. there is no way web application can change itā¦
if I get you wrong please explain your goal more detailed, like a series of steps your are looking for.
still donāt get what you are looking for. do you want to open another website and pass a Nextcloud file name as parameter? sounds little weird for meā¦ what do you try to achieve? if you describe the whole idea/process you want to establish the community might have some ideasā¦
How does one make a custom file option. Right now the options are āAdd to favoritesā āDetailsā āRenameā āMove or Copyā āOpen Withā āDeleteā
what if i want to be able to click on āfilenameā and have the option to go to newsite.com/filename
