I activate and it goes to login and the two passwords it gives do not work with ncp as living or pi raspberry and I have formated this 7 times in imager to start over. I’m going to try the credentials from imager but I just can’t seen to get this coming. I’m in a look. Do I need this bonjour? I used admin as uid. One time I got into the UI and it timed out so I had to put in this uname and pass. Didn’t work. I starting to think this is some bs , what else can I try. Total bs and so frustrating.
Not knowing which image you are using I assume you try the latest NextcloudPi_RaspberryPi4_v1.55.1.zip or for rpi5, I don’t know.
Sure you read that this version is not based on RasperryOs anymore but on armbian.
So you may have a look there too:
Armbian Quick Start Guide
