Iām using the official Nextcloud docker image (15-fpm-alpine) with nginx SSL proxy. I started using the docker-compose example which I found here:
The Nextcloud docker instance is configured for https requests on port 8443 (thereās another web server running on this machine). The nginx https proxy passes the requests via http to the nginx web server instance which serves the Nextcloud pages.
I can login using the web interface and I can sync my files with WebDAV.
However, Iām still having troubles to connect the official Linux client (latest beta client from Ubuntu PPA; I also tried the AppImage but with no difference) with my Nextcloud instance.
What I can see in the log window is that the client complains that the login form is provided over http while the page itself is served via https (at least thatās my assumption of whatās going wrong here):
[OCC::CheckServerJob::finished status.php returns: QJsonDocument({"edition":"","installed":true,"maintenance":false,"needsDbUpgrade":false,"productname":"Nextcloud","version":"15.0.2.0","versionstring":"15.0.2"}) QNetworkReply::NetworkError(NoError) Reply: QNetworkReplyHttpImpl(0x556a6f8bb230)
[OCC::DetermineAuthTypeJob::start Determining auth type for QUrl("https://myserver.mydomain.lan:8443/remote.php/webdav/")
[OCC::AccessManager::createRequest 2 "" "https://myserver.mydomain.lan:8443/remote.php/webdav/" has X-Request-ID "22afa9a3-7964-4fd0-aa4e-b06a9f5b9a98"
[OCC::AbstractNetworkJob::start OCC::SimpleNetworkJob created for "https://myserver.mydomain.lan" + "" "OCC::Account"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://myserver.mydomain.lan:8443/remote.php/webdav/" has X-Request-ID "e879ab82-572a-41ba-adba-6869075b2339"
[OCC::DetermineAuthTypeJob::checkBothDone Auth type for QUrl("https://myserver.mydomain.lan:8443/remote.php/webdav/") is 3
[OCC::WebViewPage::initializePage Url to auth at: "https://myserver.mydomain.lan:8443/index.php/login/flow"
[unknown Mixed Content: The page at 'https://myserver.mydomain.lan:8443/index.php/login/flow' was loaded over a secure connection, but contains a form which targets an insecure endpoint 'http://myserver.mydomain.lan:8443/login/flow/apptoken'. This endpoint should be made available over a secure connection.
[unknown Mixed Content: The page at 'https://myserver.mydomain.lan:8443/login/flow/grant?clientIdentifier=&stateToken=EFK3AdrBBsyZZvjOK8x8aODsyZoKYtRWg1JqbdJG2fqFPLm97Y60KLSapwbqtrip' was loaded over a secure connection, but contains a form which targets an insecure endpoint 'http://myserver.mydomain.lan:8443/login/flow'. This endpoint should be made available over a secure connection.
[unknown Mixed Content: The page at 'https://myserver.mydomain.lan:8443/login/flow' was loaded over a secure connection, but contains a form which targets an insecure endpoint 'http://myserver.mydomain.lan:8443/login/flow/apptoken'. This endpoint should be made available over a secure connection.
So my interpretation is that the problem seems to be caused by the Nextcloud App which runs on http and the nginx SSL proxy which translates all requests for the Nextcloud App. Unfortunately, I was not able to find reasonable measures to track down the problem by searching the internet. So I would be very glad if someone with more experience in this field would be able to help me.
Regards,
AndrƩ
