Access denied State token does not match
I have just installed nextcloud as a docker on my unRAID server and all working as expected via my Android devices but I am trying to set up my Windows Desktop PC as a client and use my local ip & port of the nextcloud server, I get a message saying the certificate does not match to which I apply connect anyway, this then takes me to the login screen and upon entering my username and password I get “Access denied State token does not match”
It works fine if I use my WAN address HTTPS://..co.uk
Can anyone help please?
Many Thanks
Did you get this sorted? I am having the same problem.
Hi yes I did, please read this thread
