Did a fresh install of 21.0.1 to my server, after creating database this error occoured;
When i refresh the page it started to return Access denied. as below;
What am i doing wrong and how to fix it?
guess it is denied due to untrusted address
pls check and add the address you used into the config.php
For trusted domains, it’s just the first entry that is needed (the others are URLs)
Please check your logfiles. Could be a database connection, file permissions, …
added below lines to config.php
“log_type” => “file”,
“logfile” => “nextcloud.log”,
“loglevel” => 0,
“logdateformat” => “F d, Y H:i:s”,
here is the log output;
{"reqId":"xJQl7LwK2aqPdclfNpZk","level":0,"time":"May 17, 2021 07:38:49","remoteAddr":"176.43.108.199","user":"--","app":"files_sharing","method":"GET","url":"/","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:88.0) Gecko/20100101 Firefox/88.0","version":"21.0.1.1"}
