A problem with templates for custom theme - /themes
  • Nextcloud Server version - 32.0.0.13
  • Operating system and version - Ubuntu 24.04.3
  • Web server and version - Apache/2.4.58
  • PHP version - PHP 8.3.6
I have created a custom theme in the /themes directory, and according to the documentation, I should be able to override the core/templates/layout.user.php template. To do this, I have created a file in the following path within my theme:
themes/mytheme/core/templates/layout.user.php
The theme is definitely activated, and I have cleared all caches, but none of the changes I have made to my overridden template are taking effect on the site.
Has anyone encountered this issue? Is there a reason why Nextcloud is not loading the redefined template from the theme directory? I would appreciate any suggestions or ideas on how to debug this.
We are running into this same issue. The theme templates don’t work in nextcloud version 32.
Just curious, did you manage to find a solution to this?
the issue seems to go away if you enclose your themes’ core folder in ‘app‘ folder.
so the directory would look like
“/themes/theme_name/apps/core”
, you can further change back to original method if you change condition in the
lib/private/Template/Template.php
    protected function findTemplate(string $theme, string $app, string $name): array {
        // Check if it is a app template or not.
        // if ($app !== '') {
        if ($app !== '' && $app !== 'core') {  //<- this condition like this
            try {
                $appDir = Server::get(IAppManager::class)->getAppPath($app);
            } catch (AppPathNotFoundException) {
                $appDir = false;
            $dirs = $this->getAppTemplateDirs($theme, $app, \OC::$SERVERROOT, $appDir);
        } else {
            $dirs = $this->getCoreTemplateDirs($theme, \OC::$SERVERROOT);
        $locator = new TemplateFileLocator($dirs);
        return $locator->find($name);
