A problem occuers while downloading apps inside NC
I was downloaidng calender inside NextCLoud but this error message have appeared :
An error occurred during the request. Unable to proceed.
Could not extract app calendar: Error while opening {/tmp/oc_tmp_FxLiCN-folder/calendar/js/calendar-src_views_Calendar_vue-data_image_svg_xml_3csvg_20xmlns_27http_www_w3_org_2000_svg_27_20heigh-565c85.js} in write binary mode
Also the same message appears with some random applications. I’m using Debian 12 and CasaOS with MariaDB.
hi @mwalid207 welcome to the forum :handshake:
you are missing the required support template. Please fill this form out and edit into your post. This will give us the technical info and logs needed to help you in case the machine in question in spitting out errors! Since you’ve provided zero technical details it is impossible to help you as-is. Thanks.
Please use the search - lot of issues have been discussed already
If there are specific issues or error please describe what you tried so far and which problems you hit!
