Nextcloud version 20.0.4: with encryption
Operating system and version Debian 10:
Apache or nginx version 1.14.2-2+deb10u3:
PHP version 7.3:
App enabled list bellow.
After a migration 20.0.0 to 20.0.4 with all version (I made 20.0.0 > 20.0.1 > 20.0.2 > 20.0.3 > 20.0.4) nextcloud work successfully.
But this week, a friend warn me because some of his file is not accessible. Nextcloud return a 503 error : Encryption not ready: multikeydecrypt with share key failed:error:04065072:rsa routines:rsa_ossl_private_decrypt:padding check failed
The problem is located between 16 december (last update of my friend’s file) and this week. But I launch upgrade the 21 december.
Of course, my backups are only one week long, so… I couldn’t go back any more (otherwise I won’t bother you with my problem).
I’ve tested everything that comes into my head (with rollback on the terrible day when I discover the disaster on each failed):
- Use nextcloud-tools. Result “decryption failed”
- Use
php occ encryption:decrypt-all
: failed - Use PHP 7.4. Nothing
- Rollback to Nextcloud 20.0.0 and replace all app by last tar of app present the day of update (so all apps between 20.0.3 > 20.0.4… I don’t know how I can get all previous app…) : The result of
is positive : all file are decrypted. But there aren’t decrypted - Try to understand Encryption details — Nextcloud latest Administration Manual latest documentation … But I don’t understand to complicated for me actually.
- Search solution on internet (this forum, github, google…) but… I don’t found an anwser
Is this the first time you’ve seen this error? Yes:
I don’t know. I just run upgrade and… I can’t decrypt file now
The output of your Nextcloud.log (I remove some letter of private key but not all (and is not a problem. If I can resolve this problem, I uncrypt all :
"reqId": "K7RZmca6cXs4k0EIrMzG",
"level": 4,
"time": "2021-01-08T21:51:58+00:00",
"remoteAddr": "10.10.10.1",
"user": "Dryusdan",
"app": "webdav",
"method": "GET",
"url": "/remote.php/webdav/Audio/Examen%20Middlemarch%20v2_data/e08/d04/e080411e.au",
"message": {
"Exception": "Sabre\\DAV\\Exception\\ServiceUnavailable",
"Message": "Encryption not ready: multikeydecrypt with share key failed:error:04065072:rsa routines:rsa_ossl_private_decrypt:padding check failed",
"Code": 0,
"Trace": [
"file": "/var/www/cloud_drycat_fr/apps/dav/lib/Connector/Sabre/File.php",
"line": 436,
"function": "convertToSabreException",
"class": "OCA\\DAV\\Connector\\Sabre\\File",
"type": "->",
"args": [
"__class__": "OCA\\Encryption\\Exceptions\\MultiKeyDecryptException"
"file": "/var/www/cloud_drycat_fr/www/3rdparty/sabre/dav/lib/DAV/CorePlugin.php",
"line": 90,
"function": "get",
"type": "->",
"args": []
"file": "/var/www/cloud_drycat_fr/www/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",
"line": 89,
"function": "httpGet",
"class": "Sabre\\DAV\\CorePlugin",
"type": "->",
"args": [
"__class__": "Sabre\\HTTP\\Request"
"__class__": "Sabre\\HTTP\\Response"
"file": "/var/www/cloud_drycat_fr/www/3rdparty/sabre/dav/lib/DAV/Server.php",
"line": 474,
"function": "emit",
"class": "Sabre\\DAV\\Server",
"type": "->",
"args": [
"method:GET",
"line": 251,
"function": "invokeMethod",
"type": "->",
"args": [
"line": 319,
"function": "start",
"type": "->",
"args": []
"file": "/var/www/cloud_drycat_fr/apps/dav/appinfo/v1/webdav.php",
"line": 84,
"function": "exec",
"type": "->",
"args": []
"file": "/var/www/cloud_drycat_fr/www/remote.php",
"line": 167,
"args": [
"function": "require_once"
"File": "/var/www/cloud_drycat_fr/apps/dav/lib/Connector/Sabre/File.php",
"Line": 668,
"Previous": {
"Exception": "OCA\\Encryption\\Exceptions\\MultiKeyDecryptException",
"Message": "multikeydecrypt with share key failed:error:04065072:rsa routines:rsa_ossl_private_decrypt:padding check failed",
"Code": 0,
"Trace": [
"file": "/var/www/cloud_drycat_fr/apps/encryption/lib/KeyManager.php",
"line": 480,
"function": "multiKeyDecrypt",
"class": "OCA\\Encryption\\Crypto\\Crypt",
"type": "->",
"args": [
null,
null,
"-----BEGIN PRIVATE KEY-----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\ncJqxUq2e/y9cDUWQHjyoQpJbV1O6qY/su8S5TUD9YZyfE5\n2l81YCeRDwC1Lhe7JXdZ3PWe6u7o39PrL8xSqGEA3MGsxr7Oq7jV6ejVyuTeSOjG\nmEECggEAb/kBFx4lNIeOUQkKBYzF39/JPAEDLHCauqNCmgl8FcUTz8awUsXII8Qj\nhXt+vKPc7cEEpt8GOxZ4pcY42AR0tTgnOigXtb4Qkl7Xie3\nG+5WUd2CjvezCHgav7QRlrYzQF1Z0XOYrSwjUnd0l0QEU+BCYSIVIzKmO/fUl6My\np01v60ekN1GSVhLEkA1p8ZlWAkqMfB+OUfIDXiNO8JRzCSORxn9vt0OvhjmKIyPc\n39duymQeGyF2GRZTgCSybaSPcMDG/dBI95xFIeAzIAulB+9rx0m2th3Cy255A0on\n5yo5Z9iL13a0GV/hePKzjmHlzR5a7w==\n-----END PRIVATE KEY-----\n"
"file": "/var/www/cloud_drycat_fr/apps/encryption/lib/Crypto/Encryption.php",
"line": 202,
"function": "getFileKey",
"class": "OCA\\Encryption\\KeyManager",
"type": "->",
"args": [
"/Dryusdan/files/Audio/Examen Middlemarch v2_data/e08/d04/e080411e.au",
"master_08991a95"
"file": "/var/www/cloud_drycat_fr/www/lib/private/Files/Stream/Encryption.php",
"line": 268,
"function": "begin",
"class": "OCA\\Encryption\\Crypto\\Encryption",
"type": "->",
"args": [
"Dryusdan",
"r",
"oc_encryption_module": "OC_DEFAULT_MODULE",
"cipher": "AES-256-CTR",
"signed": "true"
"function": "stream_open",
"class": "OC\\Files\\Stream\\Encryption",
"type": "->",
"args": [
"ocencryption://",
"r",
0,
null
"line": 207,
"function": "fopen",
"args": [
"ocencryption://",
"r",
false,
null
"line": 187,
"function": "wrapSource",
"type": "::",
"args": [
null,
null,
"ocencryption",
"r"
"file": "/var/www/cloud_drycat_fr/www/lib/private/Files/Storage/Wrapper/Encryption.php",
"line": 473,
"function": "wrap",
"type": "::",
"args": [
null,
"files/Audio/Examen Middlemarch v2_data/e08/d04/e080411e.au",
"signed": "true"
"Dryusdan",
"__class__": "OCA\\Encryption\\Crypto\\Encryption"
"cache": null,
"scanner": null,
"watcher": null,
"propagator": null,
"updater": null,
"__class__": "OC\\Files\\Storage\\Wrapper\\Quota"
"cache": null,
"scanner": null,
"watcher": null,
"propagator": null,
"updater": null,
"__class__": "OC\\Files\\Storage\\Wrapper\\Encryption"
"__class__": "OC\\Encryption\\Util"
"__class__": "OC\\Encryption\\File"
"r",
1439600,
1060956,
8192,
true
"file": "/var/www/cloud_drycat_fr/www/lib/private/Files/Storage/Wrapper/Wrapper.php",
"line": 300,
"class": "OC\\Files\\Storage\\Wrapper\\Encryption",
"type": "->",
"args": [
"r"
"file": "/var/www/cloud_drycat_fr/apps/files_accesscontrol/lib/StorageWrapper.php",
"line": 325,
"class": "OC\\Files\\Storage\\Wrapper\\Wrapper",
"type": "->",
"args": [
"r"
"file": "/var/www/cloud_drycat_fr/www/lib/private/Files/View.php",
"line": 1165,
"class": "OCA\\FilesAccessControl\\StorageWrapper",
"type": "->",
"args": [
"r"
"line": 1001,
"function": "basicOperation",
"class": "OC\\Files\\View",
"type": "->",
"args": [
"fopen",
"/Audio/Examen Middlemarch v2_data/e08/d04/e080411e.au",
"read"
"r"
"line": 434,
"type": "->",
"args": [
"Audio/Examen Middlemarch v2_data/e08/d04/e080411e.au",
"r"
"line": 90,
"function": "get",
"type": "->",
"args": []
"line": 89,
"type": "->",
"args": [
"line": 474,
"function": "emit",
"type": "->",
"args": [
"method:GET",
"line": 251,
"type": "->",
"args": [
"line": 319,
"type": "->",
"args": []
"line": 84,
"function": "exec",
"type": "->",
"args": []
"line": 167,
"args": [
"File": "/var/www/cloud_drycat_fr/apps/encryption/lib/Crypto/Crypt.php",
"Line": 682,
"Hint": "multikeydecrypt with share key failed:error:04065072:rsa routines:rsa_ossl_private_decrypt:padding check failed"
"CustomMessage": "--"
"userAgent": "gvfs/1.46.1",
"version": "20.0.4.0"
The cloud has had 3 different domains one after the other :
- cloud.dryusdan.fr
- cloud.drycat.fr
- dryusdan.cloud
I’ve just noticed a small error in this configuration ('overwrite.cli.url'
). I think is not important, right ?
'instanceid' => 'REDACTED',
'passwordsalt' => 'REDACTED',
'secret' => 'REDACTED',
0 => 'dryusdan.cloud',
'datadirectory' => '/var/www/cloud_drycat_fr/www/data/',
'overwrite.cli.url' => 'https://cloud.dryusdan.fr',
'dbtype' => 'pgsql',
'version' => '20.0.4.0',
'dbname' => 'nextcloud',
'dbhost' => '10.10.11.3',
'dbuser' => 'nextcloud',
'dbpassword' => 'REDACTED',
'theme' => '',
'loglevel' => 0,
'redis' =>
'host' => 'localhost',
'port' => 6379,
'timeout' => 0,
'dbindex' => 0,
'mail_smtpmode' => 'smtp',
'mail_domain' => 'drycat.fr',
'mail_smtphost' => 'mail.dryusdan.fr',
'mail_smtpport' => '587',
'mail_smtptimeout' => 30,
'mail_smtpdebug' => true,
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtpname' => 'noreply@drycat.fr',
'mail_smtppassword' => 'Dryusdan/04',
'app_install_overwrite' =>
0 => 'admin_notifications',
1 => 'end_to_end_encryption',
2 => 'mindmaps',
3 => 'twofactor_rcdevsopenotp',
4 => 'ocsms',
5 => 'dropit',
6 => 'social',
7 => 'announcementcenter',
8 => 'cookbook',
9 => 'camerarawpreviews',
10 => 'files_photospheres',
11 => 'unsplash',
12 => 'quicknotes',
13 => 'music',
14 => 'breezedark',
15 => 'extract',
'apps_paths' =>
0 =>
'path' => '/var/www/cloud_drycat_fr/apps',
'url' => '/external-apps',
'writable' => true,
'has_rebuilt_cache' => true,
'encryption.legacy_format_support' => true,
'encryption.key_storage_migrated' => false,
App enabled :
- accessibility: 1.6.0
- activity: 2.13.4
- admin_audit: 1.10.0
- announcementcenter: 4.0.0
- apporder: 0.11.0
- bookmarks: 4.0.5
- bruteforcesettings: 2.0.1
- calendar: 2.1.2
- carnet: 0.23.7
- circles: 0.20.6
- cloud_federation_api: 1.3.0
- comments: 1.10.0
- contacts: 3.4.2
- contactsinteraction: 1.1.0
- cookbook: 0.7.7
- cospend: 1.2.7
- dav: 1.16.2
- deck: 1.2.2
- encryption: 2.8.1
- event_update_notification: 1.1.0
- external: 3.7.1
- extract: 1.3.0
- federatedfilesharing: 1.10.2
- federation: 1.10.1
- files: 1.15.0
- files_accesscontrol: 1.10.1
- files_automatedtagging: 1.10.1
- files_external: 1.11.1
- files_markdown: 2.3.1
- files_pdfviewer: 2.0.1
- files_photospheres: 1.20.0
- files_rightclick: 0.17.0
- files_sharing: 1.12.1
- files_trashbin: 1.10.1
- files_versions: 1.13.0
- files_videoplayer: 1.9.0
- firstrunwizard: 2.9.0
- gpxpod: 4.2.4
- groupfolders: 8.2.0
- logreader: 2.5.0
- lookup_server_connector: 1.8.0
- news: 15.1.1
- nextcloud_announcements: 1.9.0
- notes: 4.0.2
- notifications: 2.8.0
- oauth2: 1.8.0
- password_policy: 1.10.1
- photos: 1.2.1
- polls: 1.6.2
- privacy: 1.4.0
- provisioning_api: 1.10.0
- quota_warning: 1.9.1
- recommendations: 0.8.0
- serverinfo: 1.10.0
- settings: 1.2.0
- sharebymail: 1.10.0
- side_menu: 1.21.0
- social: 0.4.2
- socialsharing_diaspora: 2.1.0
- socialsharing_email: 2.1.0
- socialsharing_facebook: 2.1.0
- socialsharing_twitter: 2.1.0
- spreed: 10.0.4
- support: 1.3.0
- systemtags: 1.10.0
- talk_matterbridge: 1.21.0
- tasks: 0.13.6
- text: 3.1.0
- theming: 1.11.0
- twofactor_backupcodes: 1.9.0
- twofactor_totp: 5.0.0
- twofactor_u2f: 6.0.0
- updatenotification: 1.10.0
- user_status: 1.0.1
- viewer: 1.4.0
- weather_status: 1.0.0
- workflow_ocr: 1.20.1
- workflowengine: 2.2.0
The output of your Apache/nginx/system log in /var/log/nginx/cloud.access.log
10.10.10.1 - Dryusdan [08/Jan/2021:22:54:29 +0100] "GET /remote.php/webdav/Audio/Examen%20Middlemarch%20v2_data/e08/d04/e0804a2d.au HTTP/1.1" 503 347 "-" "gvfs/1.46.1"
Thank by advance of your help
Regard
