I am trying to run Nextcloud on NGiNX 1.18 on Ubuntu 20.04. Right now I want to get Nextcloud running on purely port 80 with no SSL. I have the following config file in /etc/nginx
server {
listen 80;
listen [::]:80;
server_name subdomain.domain.com;
set $base /var/www/cloud;
root $base/var/www/cloud;
# debug log
error_log /var/log/nginx/debug.log debug;
error_log /var/log/nginx/warn.log warn;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
# Pagespeed is not supported by Nextcloud, so if your server is built
# with the `ngx_pagespeed` module, uncomment this line to disable it.
#pagespeed off;
# HTTP response headers borrowed from Nextcloud `.htaccess`
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
# Specify how to handle directories -- specifying `/index.php$request_uri`
# here as the fallback means that Nginx always exhibits the desired behaviour
# when a client requests a path that corresponds to a directory that exists
# on the server. In particular, if that directory contains an index.php file,
# that file is correctly served; if it doesn't, then the request is passed to
# the front-end controller. This consistent behaviour means that we don't need
# to specify custom rules for certain paths (e.g. images and other assets,
# `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
# `try_files $uri $uri/ /index.php$request_uri`
# always provides the desired behaviour.
index index.php index.html /index.php$request_uri;
# Default Cache-Control policy
expires 1m;
# Rule borrowed from `.htaccess` to handle Microsoft DAV clients
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Make a regex exception for `/.well-known` so that clients can still
# access it despite the existence of the regex rule
# `location ~ /(\.|autotest|...)` which would otherwise handle requests
# for `/.well-known`.
location ^~ /.well-known {
# The following 6 rules are borrowed from `.htaccess`
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
# Anything else is dynamically handled by Nextcloud
location ^~ /.well-known { return 301 /index.php$uri; }
try_files $uri $uri/ =404;
# Rules borrowed from `.htaccess` to hide certain paths from clients
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; }
# Ensure this block, which passes PHP files to the PHP process, is above the blocks
# which handle static assets (as seen below). If this block is not declared first,
# then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
# to the URI, resulting in a HTTP 500 error response.
location ~ \.php(?:$|/) {
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ \.(?:css|js|svg|gif)$ {
expires 6M; # Cache-Control policy borrowed from `.htaccess`
access_log off; # Optional: Don't log access to assets
location ~ \.woff2?$ {
expires 7d; # Cache-Control policy borrowed from `.htaccess`
location / {
try_files $uri $uri/ /index.php$request_uri;
I am getting an error 502 Bad Gateway. My debug log shows:
2020/12/31 03:30:10 [notice] 1384#1384: *10 "^DavClnt" does not match "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 Edg/87.0.664.66", client: 192.168.4.2, server: subdomain.domain.com, request: "GET / HTTP/1.1", host: "192.168.4.204"
2020/12/31 03:30:10 [error] 1384#1384: *10 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.4.2, server: subdomain.domain.com, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.4.204"
2020/12/31 03:30:10 [error] 1384#1384: *10 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.4.2, server: subdomain.domain.com, request: "GET /favicon.ico HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.4.204"
2020/12/31 03:30:17 [notice] 1384#1384: *10 "^DavClnt" does not match "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.88 Safari/537.36 Edg/87.0.664.66", client: 192.168.4.2, server: subdomain.domain.com, request: "GET / HTTP/1.1", host: "192.168.4.204"
2020/12/31 03:30:17 [error] 1384#1384: *10 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.4.2, server: subdomain.domain.com, request: "GET / HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.4.204"
2020/12/31 03:30:17 [error] 1384#1384: *10 connect() failed (111: Connection refused) while connecting to upstream, client: 192.168.4.2, server: subdomain.domain.com, request: "GET /favicon.ico HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "192.168.4.204"
