Nextcloud version : 16.0
Operating system and version : LinuxMint 19.2
Apache or nginx version : Apache 2
PHP version : 7.3
Is this the first time you’ve seen this error? : Y
Hi everyone,
After 5 hours for installing and configure Apache, MariaDB, MySQL, PHP, Nextcloud, I finally succeeded to obtain my nextcloud server, I configure my admin login, admin password, the places where my data is, and all works it (I was on the web interface).
But without apparent reasons (I think I restart the Apache Server), I obtain a
Not Found
The requested URL was not found on this server.
Apache/2.4.41 (Ubuntu) Server at 127.0.1.1 Port 443
If it helps, I’ve set up an SSL connection (before Nextcloud works, so I do not think it’s related to that), hence port 443.
Also note that I got the warning
Could not reliably determine the server's fully qualified domain name,
using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
And i edit apache2.conf by adding ServerName localhost, following a tutorial, I make this after the first success on my nextcloud, maybe the problem comes from there.
Thanks to read me.
EDIT : I remove ServerName localhost
of apache2.conf, but the problem persist.
