403 from Nextcloud after system upgrade
Nextcloud version (eg, 20.0.5): 25.0.8.2
Operating system and version (eg, Ubuntu 20.04): openSUSE Leap 15.4
Apache or nginx version (eg, Apache 2.4.25): nginx/1.21.5
PHP version (eg, 7.4): 7.4.33
I just upgraded my system from openSUSE 15.3 to 15.4, and when I restarted, my Nextcloud instance started giving 403s on seemingly any request. This is different from the default nginx 403 page - it’s just a blank page with the text Access denied..
I also just upgraded from an older Nextcloud version, but I don’t think that is related, since it was working after the upgrade and before I upgraded my system.
The instance itself seems to be fine:
# sudo -u wwwrun php occ status
  - installed: true
  - version: 25.0.8.2
  - versionstring: 25.0.8
  - edition:
  - maintenance: false
  - needsDbUpgrade: false
  - productname: Nextcloud
  - extendedSupport: false
The nginx error.log provides some insight
2023/06/30 11:22:11 [error] 17668#17668: *105813 FastCGI sent in stderr: "PHP message: PHP Warning:  Unknown: failed to open stream: Permission denied in Unknown on line 0Unable to open primary script: /srv/www/htdocs/nextcloud/index.php (Permission denied)" while reading response header from upstream, client: 192.168.0.27, server: [internal domain name], request: "GET /index.php/apps/photos/service-worker.js HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "[internal domain name]"
but permissions shouldn’t have changed, they look fine, and I’m struggling to figure out what exactly is going wrong here.
Is this the first time you’ve seen this error? (Y/N): Yes
I found the log file with occ, but it’s huge and the last entry was from before I upgraded, so it doesn’t seem relevant to me.
  'instanceid' => '…',
  'passwordsalt' => '…',
  'secret' => '…',
    0 => '[internal domain name]',
    1 => '10.0.0.1',
  'datadirectory' => '/home/server/data/nextcloud',
  'version' => '25.0.8.2',
  'overwrite.cli.url' => '[internal domain name]',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost:3306',
  'dbuser' => '…',
  'dbpassword' => '…',
  'twofactor_enforced' => 'false',
  'theme' => '',
  'loglevel' => 2,
  'app_install_overwrite' =>
    0 => 'dashboard',
  'redis' =>
    'host' => '127.0.0.1',
    'port' => 6379,
  'updater.secret' => '…',
What? My Nextcloud installation directory doesn’t have any logs.
I found a clue in audit.log - AppArmor was at fault. I don’t know how to use it and I’m lazy, so I just disabled it. Works fine now.
