Hi my logfile was getting really big latley (over 100GB). After I have had a look at it, I noticed that there is just one error message repeating insanly often, hundreds of errors per second. Here it is:
{"reqId":"Y3KLJzrhtKX4pKF7u1ww","level":3,"time":"2018-08-17T17:06:30+02:00","remoteAddr":"REMOVED","user":"USER","app":"PHP","method":"MOVE","url":"\/nextcloud\/remote.php\/dav\/uploads\/USER\/1654872603\/.file","message":"fseek() expects parameter 2 to be integer, float given at \/var\/www\/nextcloud\/3rdparty\/icewind\/streams\/src\/Wrapper.php#74","userAgent":"Mozilla\/5.0 (Linux) mirall\/2.3.3 (Nextcloud)","version":"13.0.5.2"}
I have no idea where this comes from. Did I do something wrong or this a software bug?
Thank you for your help.
Nextcloud version: 13.0.5.2
Operating system and version: Raspbian (Deebian Strech)
Apache or nginx version: nginx 1.10.3
PHP version: 7.0.30
Error PHP fseek() expects parameter 2 to be integer, float given at /var/www/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#74 2018-08-17T17:06:30+0200
config.php:
'instanceid' => 123',
'passwordsalt' => '456',
'secret' => '789',
0 => 'abc.abc',
1 => 'www.abc.abc',
2 => 'abc.def',
'datadirectory' => '/mnt/ssd/nextcloud/data',
'overwrite.cli.url' => 'https://abc.abc/nextcloud',
'version' => '13.0.5.2',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud_db_user',
'dbpassword' => 'abc123',
'skeletondirectory' => '',
'loglevel' => 3,
'filelocking.enabled' => false,
