2FA for clients
Setup
The Installation I host, runs the latest production stable NC in combination with latest clients (Win, iOS & Android).
Use Case
Iā€˜m granting my users the privilege of an easy password, because they (have to) use 2FA (TOTP). From my perspective this should minimize security risks by maximum comfort.
But recently I discovered, that clients donā€˜t support 2FA. The implementation of 2FA for first logon to a client (afterwards youā€˜ll have an App-Token), would align security standards.
Your comments are more than welcome!
:wink:
The app tokens are usually more complex than ā€œnormalā€ passwords. On a desktop client, I see that it can be interesting to use, on a mobile client already a bit less because you need compatible hardware (and still different hardware, because if it is just an app on the same device, it’s not really a second, independent factor).
Not sure, the second factor should be a real second factor. If the password is too trivial, the second factor becomes your real ā€œpasswordā€.
