How to fix or rollback? Unfortunately i’m not an advanced in linux.
Now my server have “Update in process” status and i’m unable to do anything.
Maybe some console commands i need to use to repair?
Thanks for help i waitng for.
Yeah I had the same problem just yesterday. What I did is I checked my config file. To see what version nextcloud is in the config file. Then I downloaded the correct nextcloud. (So this is how I rolled my nextcloud back to 25.0.4.1) I then renamed my nextcloud file in the /var/www/nextcloud to /var/www/nextcloud -old. Then unzip the nextcloud you just downloaded. When that’s done. You need to copy the config the data and the apps file from your old nextcloud to the new one. Then you should have access to the system. You might get a message saying system is in maintenance if you get that message then you will need to adjust your configuration or use the OCC command to turn off maintenance. I simply just opened up my config file and change maintenance from true to false. I hope this helps
Before I forget. If you do it this way you will have to run the sudo chown -R www-data:www-data nextcloud/ command so all the files you just put there Will have the appropriate permissions
My question really is why did this happen to us. And what is the fix for it. Does anyone else know? I’m going to give it a try on the command line to see if it will complete the update.
I updated to 25.0.5 as well over the web and after that I tried to replace my container with the 25.0.5 image, but there is none. The docker image is still on 25.0.4. That is probably why you have that odd behaviour.
Also sucks for me since I cannot start the container anymore till 25.0.5 comes as image (no time to tinker around with it).
I still don’t see any mention of version 25.0.5 on the update history page Changelog - Nextcloud
Perhaps this is some kind of technical error and the update is not yet fully ready
i tried to run the updater on command line and it wouldn’t let me. this is the fails any ideas?
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/clippy.svg,/var/www/nextcloud/updater/…/core/img/actions/clippy.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/close.svg,/var/www/nextcloud/updater/…/core/img/actions/close.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/comment.png,/var/www/nextcloud/updater/…/core/img/actions/comment.png): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/more.svg,/var/www/nextcloud/updater/…/core/img/actions/more.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/password-white.svg,/var/www/nextcloud/updater/…/core/img/actions/password-white.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/password.png,/var/www/nextcloud/updater/…/core/img/actions/password.png): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/password.svg,/var/www/nextcloud/updater/…/core/img/actions/password.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/pause.svg,/var/www/nextcloud/updater/…/core/img/actions/pause.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
PHP Warning: rename(/mnt/2018BA0A2C80DD9C/DATA/data/updater-ocwdythscb5a/downloads/nextcloud/core/img/actions/phone.svg,/var/www/nextcloud/updater/…/core/img/actions/phone.svg): Operation not permitted in phar:///var/www/nextcloud/updater/updater.phar/lib/Updater.php on line 930
Yeah I came to the same conclusion and went looking at it. Then I did my chmod and chown -R again but for some reason the drive never changed ownership. It stayed set to root. And I was never able to change it. No matter what I did it would not change ownership.
Has anyone ran in to this problem with Ubuntu 22.04?
I’m thinking about going back to Ubuntu 20 I’m not sure tho
