2-way synchronization pb
When I add pictures to the phone’s folder, they are not updated in the cloud’s folder (both folders are configured for 2-way synchronization)
Nextcloud client for android
Nextcloud Server version : I don’t know it is disroot
Operating system : android 16 on pixel 8
Is this the first time you’ve seen this error : Yes
When did this problem seem to first start : as soon as 2-way synchro appears
Installation method : f-droid
have you contacted your provider?
i’ve just contacted them for you!
