I have 2 problems after I run npm run test to output and I would like to have an output clean (if it’s possible) ^^’
I have 2 types of problems :
Proxying an event bus of
[Vue warn]: Unknown custom element: <notifications> - did you register the component correctly? For recursive components, make sure to provide the "name" option.
$ npm run test
> workspace@1.0.0 test
> jest
PASS src/tests/unit/spaceService.test.js
convertGroupfolderToSpace method
✓ Return object type (6 ms)
✓ Is not undefined (2 ms)
PASS src/tests/unit/store.test.js
Vuex store tests
✓ Adds a space in the Vuex store (6 ms)
✓ Adds a group to the space (2 ms)
✓ Removes a group to the space (1 ms)
✓ Sets space quota (1 ms)
✓ Get space quota (2 ms)
✓ Adds a user to the space (1 ms)
✓ Count users in workspace (2 ms)
✓ Count users in group (1 ms)
✓ Removes a user from the space (1 ms)
console.warn
Proxying an event bus of version 3.0.2 with 1.3.0
98 | import { ESPACE_MANAGERS_PREFIX, ESPACE_USERS_PREFIX, ESPACE_GID_PREFIX } from './constants'
99 | import axios from '@nextcloud/axios'
> 100 | import Avatar from '@nextcloud/vue/dist/Components/Avatar'
101 | import Actions from '@nextcloud/vue/dist/Components/Actions'
102 | import ActionButton from '@nextcloud/vue/dist/Components/ActionButton'
103 | import Multiselect from '@nextcloud/vue/dist/Components/Multiselect'
at new ProxyBus (node_modules/@nextcloud/vue/node_modules/@nextcloud/auth/node_modules/@nextcloud/event-bus/dist/index.js:2341:15)
at getBus (node_modules/@nextcloud/vue/node_modules/@nextcloud/auth/node_modules/@nextcloud/event-bus/dist/index.js:3318:12)
at Object.<anonymous> (node_modules/@nextcloud/vue/node_modules/@nextcloud/auth/node_modules/@nextcloud/event-bus/dist/index.js:3324:11)
at Object.<anonymous> (node_modules/@nextcloud/vue/node_modules/@nextcloud/auth/lib/requesttoken.ts:1:1)
at Object.<anonymous> (node_modules/@nextcloud/vue/node_modules/@nextcloud/auth/lib/index.ts:1:1)
at Object.require [as 3607] (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/external commonjs "@nextcloud/auth":1:18)
at moduleId (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/webpack/bootstrap:19:22)
at Object.gt [as 3351] (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/l10n.js:40:27)
at node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/Avatar/Avatar.vue?ac35:1:1
at node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/Avatar/Avatar.vue:24:33
at factory (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/webpack/universalModuleDefinition:3:20)
at Object.<anonymous> (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/webpack/universalModuleDefinition:1:1)
at src/SelectUsers.vue:100:1
at Object.<anonymous> (src/SelectUsers.vue:184:3)
at Object.<anonymous> (src/tests/unit/selectUsers.test.js:26:1)
console.warn
Proxying an event bus of version 3.0.2 with 2.1.1
at new warn (node_modules/@nextcloud/vue/node_modules/@nextcloud/event-bus/lib/ProxyBus.ts:17:21)
at getBus (node_modules/@nextcloud/vue/node_modules/@nextcloud/event-bus/lib/index.ts:20:16)
at Object.getBus (node_modules/@nextcloud/vue/node_modules/@nextcloud/event-bus/lib/index.ts:26:13)
at Object.require [as 542] (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/external commonjs "@nextcloud/event-bus":1:18)
console.warn
93 | <script>
94 | import axios from '@nextcloud/axios'
> 95 | import AppContent from '@nextcloud/vue/dist/Components/AppContent'
96 | import AppContentDetails from '@nextcloud/vue/dist/Components/AppContentDetails'
97 | import AppNavigation from '@nextcloud/vue/dist/Components/AppNavigation'
98 | import AppNavigationIconBullet from '@nextcloud/vue/dist/Components/AppNavigationIconBullet'
at Object.542 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/external commonjs "@nextcloud/event-bus":1:26)
at exports (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/webpack/bootstrap:22:16)
at node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/AppContent/AppDetailsToggle.vue:33:1
at node_modules/@nextcloud/vue/dist/Components/AppContent.js:1:73674
at node_modules/@nextcloud/vue/dist/Components/AppContent.js:1:73679
at node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/webpack/universalModuleDefinition:4:28
at Object.<anonymous> (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/webpack/universalModuleDefinition:11:1)
at src/Home.vue:95:1
at Object.<anonymous> (src/Home.vue:315:3)
at Object.<anonymous> (src/tests/unit/home.test.js:26:1)
console.warn
74 | import Actions from '@nextcloud/vue/dist/Components/Actions'
75 | import ActionButton from '@nextcloud/vue/dist/Components/ActionButton'
> 76 | import ActionInput from '@nextcloud/vue/dist/Components/ActionInput'
77 | import Modal from '@nextcloud/vue/dist/Components/Modal'
78 | import SelectUsers from './SelectUsers'
79 | import UserTable from './UserTable'
at Object.3351 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/mixins/actionGlobal.js:56:70)
at Object.4430 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/Avatar/Avatar.vue?ac35:1:1)
at Object.9378 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/ListItemIcon/ListItemIcon.vue?8c0e:1:1)
at Object.1471 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/Multiselect/EllipsisedOption.vue:20:33)
at Object.6251 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/TimezonePicker/TimezonePicker.vue:69:1)
at Object.4069 (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/DatetimePicker/index.scss?021a:22:1)
at node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/ActionInput/ActionInput.vue?ba53:1:1
at node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/ActionInput/ActionInput.vue:24:33
at src/GroupDetails.vue:76:1
at Object.<anonymous> (src/GroupDetails.vue:157:3)
at Object.<anonymous> (src/router.js:27:1)
at Object.<anonymous> (src/store/actions.js:24:1)
at Object.<anonymous> (src/store/index.js:26:1)
at Object.<anonymous> (src/tests/unit/home.test.js:30:1)
console.debug
Could not find capabilities initial state fall back to _oc_capabilities
at debug (node_modules/@nextcloud/capabilities/lib/index.ts:7:11)
console.error
found in
---> <Home>
<Root>
41 | localVue.use(Vuex)
42 | localVue.use(VueRouter)
> 43 | const wrappedHome = mount(Home, {
44 | store,
45 | localVue,
46 | router,
at warn (node_modules/vue/dist/vue.runtime.common.dev.js:4548:21)
at createElm (node_modules/vue/dist/vue.runtime.common.dev.js:6455:21)
at createChildren (node_modules/vue/dist/vue.runtime.common.dev.js:6562:17)
at createElm (node_modules/vue/dist/vue.runtime.common.dev.js:6466:13)
at VueComponent.patch [as __patch__] (node_modules/vue/dist/vue.runtime.common.dev.js:6991:13)
at VueComponent.Vue._update (node_modules/vue/dist/vue.runtime.common.dev.js:3718:25)
at VueComponent.updateComponent (node_modules/vue/dist/vue.runtime.common.dev.js:3828:16)
at Watcher.get (node_modules/vue/dist/vue.runtime.common.dev.js:3400:33)
at new Watcher (node_modules/vue/dist/vue.runtime.common.dev.js:3390:51)
at mountComponent (node_modules/vue/dist/vue.runtime.common.dev.js:3845:5)
at VueComponent.Object.<anonymous>.Vue.$mount (node_modules/vue/dist/vue.runtime.common.dev.js:8687:12)
at init (node_modules/vue/dist/vue.runtime.common.dev.js:4353:19)
at createComponent (node_modules/vue/dist/vue.runtime.common.dev.js:6489:17)
at createElm (node_modules/vue/dist/vue.runtime.common.dev.js:6443:13)
at mount (node_modules/@vue/test-utils/dist/vue-test-utils.js:14065:21)
at Object.<anonymous> (src/tests/unit/home.test.js:43:26)
console.info
[INFO] AppContent: falling back to global nextcloud pane config
at VueComponent.paneConfigID (node_modules/@nextcloud/vue/dist/Components/webpack:/NextcloudVue/src/components/AppContent/AppContent.vue:216:1)
console.debug
PASS src/tests/unit/home.test.js (8.84 s)
Home component tests
✓ ConvertQuotaForFrontend: Test regular quota (6 ms)
✓ ConvertQuotaForFrontend: Test unlimited quota (1 ms)
✓ Convert 10000MB to 10GB (1 ms)
✓ Convert 23GB to 23GB
✓ Convert -3 (int) to unlimited (1 ms)
✓ Convert -3 (string) to unlimited (1 ms)
✓ Return string type (1 ms)
Creating spaces with different entries
✓ Home.methods.createSpace has been called (4 ms)
✓ Create "Sri_Lanka" (3 ms)
console.debug
PASS src/tests/unit/selectUsers.test.js (8.894 s)
SelectUsers component tests
✓ addUsersToWorkspaceOrGroup test: Adding a user to a subgroup (110 ms)
✓ addUsersToWorkspaceOrGroup test: Adding a user to a workspace (115 ms)
✓ addUsersToWorkspaceOrGroup test: Adding a user to a workspace with admin role (69 ms)
Test Suites: 4 passed, 4 total
Tests: 23 passed, 23 total
Snapshots: 0 total
Time: 11.216 s, estimated 24 s
Ran all test suites.
I dont know what is the Proxying an event bus of. I don’t know how to resolve this problem
If you run npm ls @nextcloud/event-bus in your app’s root directory you will likely find that there are at least two versions of the package. The log is merely a warning. You may ignore it.
The background of this warning is that the package has to register a global variable to communicate with other instances of the package in other apps. And if the versions of the two instances don’t match it could happen that they are incompatible.
The notifications is a element you are using. I am not aware that this is an official HTML tag. It is not listed in your components. I suspect that this will cause trouble in the compile step as well or at least the browser will see an unknown HTML tag.
Regarding the other issue:
What is the version of your event bus package? Can you check with npm ls @nextcloud/event-bus? What version of @nextcloud/vue are you using?
Regarding the notifications:
In your tests, you are not activating the notifications, are you? So, this might just be a requirement to setup the test environment first if I am correct.
W.r.t. the @nextcloud/event-bus I cannot add anything useful on top of @ChristophWurst. He is more knowledge then me here.
One comment on @nextcloud/vue version 5.x vs 7.x: The version 5.x is intended for Nextcloud version up to 24. For 25 and only for 25 (and successors) you need the 7.x versions. With the version 6 a new prefix Nc was introduced on all components. So it is no longer an ActionButton but a NcActionButton.
I could fix the major of my problems and I create a PR
But, I have already the problem of the different versions of the @nextcloud/event-bus.
I think I cannot resolve this problem, so I leave it aside.
