Hello, guys. Im using lastest 0308 dev version on android. I have 2 accounts attached localIP:port (@home) and PublicIP:port (@out-internet) - autoupload function is trying to upload to both accounts. Is there a way to set to use only 1 connection/account.
also ways how its can try 1st of 2nd and use only one available - like other clients do?
Well lets say even if i have DynDNS (or other public DNS service)…i would need to set this on my router (not every router has this option) mine has, but i dont have public IP from provider (im on his local LAN) so i cant set DynDNS
I have just few ports open from ISP
so at home i use IP 192.168.1.200:5555
outside https://port.isp.com:5555 if i use this address at home it wont work.
Even when i tried to open port and use it for DynDNS it didnt worked out.
For example on android torrent client “Transmission” you set account wit some IP and then you can set also Alternate IP, always one of those works and i dont have to worry about other settings.
That means you can connect from outside your LAN to your nextcloud instance, right? How you achieve this is not important to answer your initial question.
What you have to do next is to reference https://port.isp.com:5555 to 192.168.1.200:5555 in your LAN. By doing so, https://port.isp.com:5555 will also work at home. This is what a self hosted local DNS can do for you. In addition you would need to share this information to all devices in your LAN. If you set your self hosted DNS as first DNS in your DHCP-Server this will work out.
its not solved… running own DNS server to use your NextCloud app is not solution.
This way is better to use google cloud for pictures, works everywhere…but limited capacity
Or i might try OwnCloud
well since ive installed Next cloud 5-6months ago on my NAS - Auto upload feature wasnt working on the App…so i tried up and then, now i realized its finally working, but im still bit limited to use it.
Thats why need to stick with gdrive or try owncloud (havent yet, as i thought you have have it all ready )
Not a DEV so cant really contribute…just test and report.
Appreciate all the testing and reports of course - we wouldn’t be where we are without good folks like you. And while we’d like to fix all the bugs, we have to prioritize - and 1.5 is really really near with huge improvements (including a completely rewritten auto upload) and bugfixes.
Often, you have a resolver on your router. Some models provide manual modifications. You could run you own resolver on your next cloud server (e.g. unbound) and populate the dns address via dhcp. It’s also useful to block adds and tracking domains.
With some routers you can even use the public IP on the local network without any tricks with your DNS.
On owncloud you will have the same problem because it is a network issue. A different router firmware could help.
With google, you have to upload everything to a remote server. You could as well run a next cloud setup on a real server or vserver you can rent for a couple of bugs a month.
Other idea: you run your NC only in your local network and connect to it from remote first via VPN.
