Upgraded via the web browser from 14.0.0 to 14.0.3 and now stuck in “Maintenance Mode”. I’m running Ubuntu 18.04 with nginx. 14.0.0 worked fine (sorry I upgraded). From other posts I tried the following command: “sudo -u www-data php /var/www/nextcloud/occ maintenance:mode --off” only to get a bunch of errors in the terminal window that are above my skill set to understand:
Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: could not find driver in /var/www/nextcloud/lib/private/DB/Connection.php:64
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect()
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion()
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform()
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform()
#4 /var/www/nextcloud/lib/private/DB/Connection.php(151): Doctrine\DBAL\Connection->setTransactionIsolation(2)
#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#6 /var/www/nextcloud/lib/private/DB/ConnectionFactory.php(152): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager))
#7 /var/www/nextcloud/lib/private/Server.php(630): OC\DB\ConnectionFactory->getConnection(‘mysql’, Array)
#8 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#9 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OCP\IDBConnecti…’)
#10 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OCP\IDBConnecti…’)
#11 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(‘OCP\IDBConnecti…’)
#12 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘DatabaseConnect…’)
#14 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘DatabaseConnect…’)
#15 /var/www/nextcloud/lib/private/Server.php(1532): OC\ServerContainer->query(‘DatabaseConnect…’)
#16 /var/www/nextcloud/lib/private/Server.php(352): OC\Server->getDatabaseConnection()
#17 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OC\Authenticati…’)
#19 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OC\Authenticati…’)
#20 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(68): OC\ServerContainer->query(‘OC\Authenticati…’)
#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(98): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(119): OC\AppFramework\Utility\SimpleContainer->resolve(‘OC\Authenticati…’)
#23 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OC\Authenticati…’)
#24 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(68): OC\ServerContainer->query(‘OC\Authenticati…’)
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(98): OC\AppFramework\Utility\SimpleContainer->buildClass(Object(ReflectionClass))
#26 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(119): OC\AppFramework\Utility\SimpleContainer->resolve(‘OC\Authenticati…’)
#27 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OC\Authenticati…’)
#28 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(‘OC\Authenticati…’)
#29 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#30 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OC\Authenticati…’)
#31 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OC\Authenticati…’)
#32 /var/www/nextcloud/lib/private/Server.php(364): OC\ServerContainer->query(‘OC\Authenticati…’)
#33 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#34 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OCP\IUserSessio…’)
#35 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OCP\IUserSessio…’)
#36 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(‘OCP\IUserSessio…’)
#37 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#38 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘UserSession’)
#39 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘UserSession’)
#40 /var/www/nextcloud/lib/private/Server.php(1415): OC\ServerContainer->query(‘UserSession’)
#41 /var/www/nextcloud/lib/private/Server.php(1023): OC\Server->getSession()
#42 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#43 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OC\Security\CSR…’)
#44 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OC\Security\CSR…’)
#45 /var/www/nextcloud/lib/private/Server.php(1019): OC\ServerContainer->query(‘OC\Security\CSR…’)
#46 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#47 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘CsrfTokenManage…’)
#48 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘CsrfTokenManage…’)
#49 /var/www/nextcloud/lib/private/Server.php(1878): OC\ServerContainer->query(‘CsrfTokenManage…’)
#50 /var/www/nextcloud/lib/private/Server.php(815): OC\Server->getCsrfTokenManager()
#51 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#52 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OCP\IRequest’)
#53 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OCP\IRequest’)
#54 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(‘OCP\IRequest’)
#55 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#56 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘Request’)
#57 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘Request’)
#58 /var/www/nextcloud/lib/private/Server.php(1282): OC\ServerContainer->query(‘Request’)
#59 /var/www/nextcloud/lib/private/Server.php(454): OC\Server->getRequest()
#60 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC{closure}(Object(OC\Server))
#61 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘OCP\L10N\IFacto…’)
#62 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘OCP\L10N\IFacto…’)
#63 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(165): OC\ServerContainer->query(‘OCP\L10N\IFacto…’)
#64 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}(Object(OC\Server))
#65 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(117): Pimple\Container->offsetGet(‘L10NFactory’)
#66 /var/www/nextcloud/lib/private/ServerContainer.php(132): OC\AppFramework\Utility\SimpleContainer->query(‘L10NFactory’)
#67 /var/www/nextcloud/lib/private/Server.php(1468): OC\ServerContainer->query(‘L10NFactory’)
#68 /var/www/nextcloud/lib/private/Server.php(1479): OC\Server->getL10NFactory()
#69 /var/www/nextcloud/lib/base.php(234): OC\Server->getL10N(‘lib’)
#70 /var/www/nextcloud/lib/base.php(659): OC::checkConfig()
#71 /var/www/nextcloud/lib/base.php(1068): OC::init()
#72 /var/www/nextcloud/console.php(46): require_once(’/var/www/nextcl…’)
#73 /var/www/nextcloud/occ(11): require_once(’/var/www/nextcl…’)
#74 {main}PHP Fatal error: Uncaught Doctrine\DBAL\DBALException: Failed to connect to the database: An exception occured in driver: could not find driver in /var/www/nextcloud/lib/private/DB/Connection.php:64
Stack trace:
#5 /var/www/nextcloud/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configura in /var/www/nextcloud/lib/private/DB/Connection.php on line 64
