hello all
after a crash of my old NCP i set up a new one
it got the versions 1.55.3
as all the other onces i made i gave him a fix IP adress-
but anyhow the system does not accept it
either via Web GUI either via PUTTY either linked with own screen&KB
on the CLI i used the linux RPI command raspi=config
does anyone have an idea what iām doing wrong or have similar issue ?
hmmm
finde das tool nicht auf meiner RPI
beim googeln sehe ich immer wieder RPI5 meiner ist leider noch ein RPI4
die installation scheint auch nur ueber Flashing zu gehen
jetzt meine Frage
passt das auch auf das RPI4 ?
gruss Manfred & Danke fuer die Info
Starting my ncpi4 test instance, pi4 is still my preferred sbc as of better support than new pi5, a look at .bash_history file shows the first commands on this new instance has been:
OUPS - Sorry
was following germans too
after the upgrade and a couple of reboots i could install the app
than need to understand the the old commands like ifconfig etc doesnt work anymore
nozw seems all done
tks for help
manfred
