My nextcloud installation is currently locked because permission of my directory is not set to 0770. A simple chmod 770 command did not help. The installation was running fine for a longer time beforehand.
My setup
Nextcloud runs on a docker container on a ubuntu 18.04 server. I have mounted a shared folder of my Synology NAS using /etc/fstab
//nasname/nextcloud /home/user/docker/Next/data cifs credentials=/home/user/.synology-cred,uid=33,gid=0,dir_mode=0770,file_mode=0600,nounix,vers=1.0 0 0
Here, uid=33 corresponds to the user www-data
In docker I map /home/user/docker/Next/
to /var/www/html
On my server I see the permission
drwxrwx---+ 14 www-data root 4096 Apr 29 21:27 .
drwxrwxr-x+ 18 dennis dennis 4096 Aug 25 22:27 ..
drwxr-xr-x+ 43 www-data root 4096 Mär 25 22:14 3rdparty
drwxr-xr-x+ 47 www-data root 4096 Feb 11 2021 apps
-rwxrwx---+ 1 www-data root 17900 Mär 25 22:14 AUTHORS
drwxr-xr-x+ 2 www-data root 4096 Apr 25 14:33 config
-rw-r--r--+ 1 www-data root 3900 Mär 25 22:14 console.php
-rwxrwx---+ 1 www-data root 34520 Mär 25 22:14 COPYING
drwxr-xr-x+ 22 www-data root 4096 Mär 25 22:14 core
-rw-r--r--+ 1 www-data root 5122 Mär 25 22:14 cron.php
drwxr-xr-x+ 21 www-data root 4096 Jul 2 21:54 custom_apps
drwxrwxrwx 10 root root 0 Apr 19 21:54 data
-rw-r--r--+ 1 www-data root 4123 Mär 25 22:14 .htaccess
-rw-r--r--+ 1 www-data root 156 Mär 25 22:14 index.html
-rw-r--r--+ 1 www-data root 2960 Mär 25 22:14 index.php
drwxr-xr-x+ 6 www-data root 4096 Mär 25 22:14 lib
-rwxr-xr-x+ 1 www-data root 283 Mär 25 22:14 occ
drwxr-xr-x+ 2 www-data root 4096 Mär 25 22:14 ocm-provider
drwxr-xr-x+ 2 www-data root 4096 Mär 25 22:14 ocs
drwxr-xr-x+ 2 www-data root 4096 Mär 25 22:14 ocs-provider
-rw-r--r--+ 1 www-data root 3144 Mär 25 22:14 public.php
-rwxrwx---+ 1 www-data root 5341 Mär 25 22:14 remote.php
drwxr-xr-x+ 4 www-data root 4096 Mär 25 22:14 resources
-rw-r--r--+ 1 www-data root 26 Mär 25 22:14 robots.txt
-rw-r--r--+ 1 www-data root 2446 Mär 25 22:14 status.php
drwxrwx---+ 3 www-data root 4096 Feb 11 2021 themes
-rw-r--r--+ 1 www-data root 101 Mär 25 22:14 .user.ini
-rw-r--r--+ 1 www-data root 383 Mär 25 22:14 version.php
using ls -la
. Where the data folder seems to be the problem. sudo chmod 770 -R data
runs for a while but does not change permissions. If I try to change the owner by sudo chown -R www-data data
I get a permission denied error.
If I ssh into my Synology diskstation as root user the data folder which is called nextcloud here has the following properties
d---------+ 10 root root 4096 Apr 19 21:54 nextcloud
and inside the directory
d---------+ 10 root root 4096 Apr 19 21:54 .
drwxr-xr-x 30 root root 4096 Aug 25 03:36 ..
drwx------+ 15 serveruser users 4096 Apr 25 22:48 appdata_oc2hji3rs2ih
drwx------+ 7 serveruser users 4096 Feb 14 2021 user1
drwxrwxrwx+ 3 root root 4096 May 15 15:58 @eaDir
drwx------+ 2 serveruser users 4096 Feb 11 2021 files_external
drwx------+ 5 serveruser users 4096 Mar 27 22:33 __groupfolders
-rwx------+ 1 serveruser users 542 Mar 25 22:14 .htaccess
-rwx------+ 1 serveruser users 0 Mar 25 22:14 index.html
drwx------+ 6 serveruser users 4096 May 7 13:04 user2
drwx------+ 7 serveruser users 4096 Apr 30 19:53 user3
-rwx------+ 1 serveruser users 121716861 Aug 25 22:37 nextcloud.log
-rwx------+ 1 serveruser users 0 Mar 25 22:14 .ocdata
d---------+ 13 root root 4096 Apr 19 22:16 #recycle
serveruser is a user on the Synology disc station. I use its credentials on my my server to get access to the data via fstab. On the UI I have given that user full access to the folder and all of its subfolders.
Do you have any idea how I can fix this issue? I have granted the user nuc full access to the folder and subfolders because several folders of my photo archive were not visible within the Nextcloud installation. After that, everything still worked fine. Later, maybe after an upgrade or reboot, the error occured. Nextcloud currently runs on 21.0.0.
Thanks for your help!
